Wham-Wham - BMW 1600-2 '67
Lucian
Go to solution Solved by Lucian,
49 minutes ago, Lucian said:
Fresh off the grille, 1600-2, did not get paint des,, need hub caps  will be at Woodly Park 10-31-2020, Jack should be there also ..... drive, drive drive    L
And it looks fabulous, Lucian!
Congrats,
Pic of my remaining hub caps,  one, not shown,  was so bad it had sandwiched into rim that was hit twice, I could not get it out, thanks to all  ... Lucian
'67 BMW 1600-2 Sahara/Brown 133,000 ..'73 BMW R90/6 Blk/White pin/s 155,000
12 hours ago, 72pdx02 said:
Is that polaris silver? It looks really nice, please share the paint code.
Rim paint? Rustoleum "Dull Aluminum".  The car is painted "006" Sahara which was introduced in 1970, in 1966 - 1970, Sahara paint was code "843" according to PaintRef.com (https://paintref.com/cgi-bin/colorcodedisplay.cgi?make=BMW&year=1966&con=ky&rows=50).  It looks beautiful in fresh Sahara.
Mark92131
1970 BMW 1600 (Nevada)
10 hours ago, Mark92131 said:
... The car is painted "006" Sahara which was introduced in 1970, in 1966 - 1970, Sahara paint was code "843" according to PaintRef.com (https://paintref.com/cgi-bin/colorcodedisplay.cgi?make=BMW&year=1966&con=ky&rows=50)...
Hmm...
The November 1968 paint and upholstery brochure shows Sahara as “06” (two photos below). If you receive a data dump from BMW Group Archives for a 1966 through 1970 ‘02, it will show Sahara as paint code “006”. For instance:
“The BMW 1600 VIN 1527753 was manufactured on June 06th, 1967 and delivered on June 20th, 1967 to the BMW importer Hoffman Motors Corp. in New York City. The original colour was Sahara, paint code 006.“
Lastly, and critically, that three-digit code, “843”, is unlike any paint codes of the ‘02 era: they were one and two digit codes, not counting any preceding zeros. So that’s a modern code, certainly not of the 1966-70 time period.
With this said, is that 843 code telling us something? Just as Chamonix was re-formulated (to be more creamy... or was it less creamy?) without changing the factory’s paint code, was Sahara re-formulated ca. 1970? Notwithstanding the possibility that PaintRef.com is wrong, have we been missing a color change effecting Sahara? I don’t dismiss the possibility, especially since I believe the Chamonix re-formulation occurred at a somewhat similar time.
Best regards,
I don't either, especially Polaris that has had multiple re-formulations since it's introduction.  Early Polaris, "7054" looked flat and grey compared to Polaris "7058" and Polaris "060".  I believe "060" went through multiple re-formulations until it finally ended up as Polaris "900" on the BMW 320i and other later BMW Models.
Mark92131
39 minutes ago, Mark92131 said:
I believe "060" went through multiple re-formulations until it finally ended up as Polaris "900" on the BMW 320i and other later BMW Models...
+1
And despite at least three (self-destructing) Polaris formulations used during the ‘02 era (1966-76), BMW used paint code 060 throughout that period. I believe 058 was the code from Polaris’s introduction in 1964 until 1966. Below, Polaris’s introduction in 1964: only available on the 1800ti !
There must have been a distinction between when a re-formulation (a.) warranted a new paint code or (b.) could continue under the existing code.
Best regards,
For some reason I was not able to delete my sideways photo, but my text was removed instead. I was curious what color your wheels were.. I have painted wheels in the past Polaris silver and had this can leftover. I was happy with the results.  Yours look really nice, and was interested to know what color you used. Thank you.
Hi, I waiting for Jack to answer,  I showed my spare and in middle is original color, I had a spray can and Jack laughed he could best that   He will get around to it ... see pic ... L
  • 3 weeks later...
  • 3 weeks later...
