distributor housing
I am installing the head on my 02 and I was told there is supposed to be an o ring that goes in the oil galley in the head. There are two holes that feed oil, one to the distributor, and one to the oil pressure sending unit. Does anyone know if both or either of these need a o ring? Also any other tips for installing the head?
Dave
The distributor housing uses a paper gasket. The distributor shaft does use an o-ring for a seal.
shermanmartinez@hotmail.com
looking at this diagram of the distributor housing the (1) special sealing washer goes with the bolt that is at 9-0clock position - as you look at this picture . just split or wavy lock washers for the other bolts. Without the sealing washer , YOU WILL HAVE A SERIOUS OIL LEAK - also renew the thick paper gasket when apart.
