NYTransplant
$10.05 fix for keeping pop-out vent windows from closing
12 posts / 970 viewsLast Reply
(edited)
There have been a couple rear vent window threads here in the past few days, but I thought I'd start a new one rather than burying this fix three pages deep.
For $9.99 plus the cost of four 8mm Nylon washers, this works pretty well, and isn't terribly obtrusive.
I bought two bicycle seat-post clamps on Amazon for $4.99 each.  I used silver because I have chrome latch hardware.  They also come in black if you have the black window latches.  Since I didn't have any 8mm Nylon Washers, I bought a box of assorted Nylon washers from Amazon, but if you already have these, they're super cheap.  I paid $10 for the 600pc box.  That makes the 4 washers total just under $0.07. ?
The clamps needed no modification and I didn't even have to remove the latch from the car.  I removed the old bolt and slid this in its place. They are a perfect diameter for the hole (~6mm).
I was a little disappointed at first because when I pushed it down all the way it actually loosened up rather than tightened. The clamps were overcentering a bit too far.  Once I had the nut adjusted correctly, it actually worked out better.  I just pull up on it rather than push down to tighten, and it doesn't need much travel.  Here's a video of how it works.  Please forgive my dirty headliner.  I need to give it a good scrub. ?
IMG_20190823_144016.MOV
Edited by NYTransplant
  • Like 8
Man, that's awesome. Good job. Archiving the thread for future use.
As for the headliner, go buy yourself a $4 tub of GOOP hand cleaner at HD or Autozone. Put some on your headliner, let it sit a few minutes and then wipe off with a damp rag. Works wonders!
Nick
  • Like 5
  • Thanks 2
Nick
Thanks Nick.  I actually have Orange Hand Cleaner and Goop.  All I need now is to "just do it". ?
Thank you very much for posting this. Great stuff
Sent from my SM-G950U using Tapatalk
An easier and cheaper fix if you have one of the all chrome quarter window latches (used until VIN 25874xx +/-, mid '73 production).
Tighten the little screw slot atop the chrome ball.  I have a stubby screwdriver with a ground-down blade whose sole purpose in life is to tighten those screws.  Re-tighten once a year or so (depending on how rough your roads are) and they'll stay open.  I fastened a cup hook to a dowel of appropriate length, opened the cup hook out a little and can open/close the pax side quarter window from the driver's seat.   A lot easier than adapting the power quarter window openers from a Mopar van...
Agreed.  My passenger side has this style, and it always stays open.  My driver's side had the plastic nut, and no matter how many times I tightened it, I'd eventually find it closed after a drive.
Brilliant!
Quick update...
This fix only works with the newer style latches.  The older style with the chrome knobs that @mike mentioned have a much smaller shaft diameter (~4mm) than the larger diameter shoulder screw with the plastic knob (~6mm).  These types of clamps will not fit through the hole.
Then again, if you have the older style, you can get the knob quite a bit tighter with the screw head, so you really don't need this fix.  ?
Tim
3 hours ago, bianchini said:
@NYTransplant thanks for doing this! Also, on amazon, I can't tell if the order comes with 1 or 2 bike clamps. All the photos show 2 clamps...
Price on Amazon is per each, not per pair.  Not very clear on Amazon.
Don
Any chance of some pics please, for some strange reason i cant watch the clip. TIA.
(edited)
Sure. Here’s basically what the video shows.
The first is locked  E101AA3C-8CA7-492C-91A8-C3FF1E066667.thumb.jpeg.1c28aedd401ca540b9fb3ad8afaf9ff4.jpeg
Push down to unlock
And closed
Close up
Cheers!
