nate_williams
NK Big Sway Bar Options
10 posts / 408 viewsLast Reply
I am currently running a set of stock bars from 68 2000cs on my 1800. They are a little small for track duty. What are some options? I believe front fitment is same as 02, but rear? Nate
@nate_williams I’ve been looking as well for a set for mine. Once you come up
with a solution(not IE) let me know. Also will be interested in your CS set when time comes!
I’ve heard, and have one but haven’t tried, that the ADDCO 7/8”/22mm ‘02 front bar fits NK. It’s the one you may have seen that drops down and forward of the nose.
http://www.addco.net/aftermarket/catalog/bmw/
Jaymic does make bars specific for the NK, up to 22mm front. And E9 rear bars in 22mm also.
https://www.jaymic.com/
On 8/22/2019 at 8:42 PM, HBChris said:
I think rear is same as e9.
I've got one on my CS
On 8/21/2019 at 5:33 PM, zinz said:
Ireland makes a special front bar just for NK applications.
http://www.iemotorsport.com/bmw/item/02sbset.html
Note: These will fit the 4 door Neue Klasse cars, however since the motor is more forward in these cars we recommend the stiffer drop-center bar.
what is a drop center bar?
I also have an E28 and bought IE bars but did not use them. Installation seemed a little funky. Used a different brand. Anyone know if this is the same issue woth the NK?
