Need quick help with my Bilstein install.
Rear shocks came without install directions. Came with washers, dust sleeves, 1" spacer and locking nuts. Previous pair did not use a spacer. In which order should I install everything?
Should the blue dust sleeve go over the piston, then washer, spacer through the bushing, washer and then nut. Do I use the spacer at all. The last pair had two seperate bushings without a spacer, where the new ones came with one bushing and spacer.
TIA
