sirius815
Rear seat belt mounting point (inner)
3 posts / 328 viewsLast Reply
So, I'm an idiot and cross-threaded one of the inner mounting points for the rear seat belts and bugged up the thread repair... :( Are there replacement mounts available? I haven't been under the car for a minute, but last I remember they looked to be replaceable from below. It's either that or just use a longer bolt + nut for the time being :/.
Just through bolt it with some grade 8 hardware.
Sent from my SM-G960U using Tapatalk
There are mounting plates with threaded holes (of size 7/16"-20 SAE) that you can weld or rivet under te oparcel shelf. Check out seatbeltplanet, wesco performance, etc. Large fender washers under the parcel shelf can also be used.
