02TurboMI
Tightening the Fuel Level Sender
10 posts / 375 viewsLast Reply
How do I tighten the fuel level sender? I’m thinking there is a specialized tool?
I removed my sender unit to have the tank blasted and coated with a plastic material, and now I’m getting a lot of resistance trying to tighten it. I’ve been able to rotate it a bit using a screwdriver, but any other recommendations?
thanks!
(edited)
Put a little silicone grease on the rubber seal; it won't hurt the rubber and will make turning the sender's bayonet lock much easier--and keep the seal from bunching up.  If you don't have any silicone grease, a little dab of "Personal Lubricant" (AKA KY Jelly) will work too.  That stuff is also great for...fitting radiator hoses.
Edited by mike
Fitting them where?
  • Haha 1
Silicone in the intake air or fuel will eat you WB's lunch if there is one installed.
The screwdrivers work great to remove the unit, but replacing it is a little more tedious.
@barrettN made that great tool (in post link above) which I copied.  Soooo easy to push down and turn.   I think the plumbing part was $3.00.
SenderWrench1.jpg.0c385ea0210d7bc2c2f8f536b31c7258.jpgSenderWrench2.jpg.230fbde24b1a15af0125e24a440ef57c.jpg
I think I started with a bit of downward pressure and a twist to engage, then used a shop-towel over the tip of a broad screwdriver set into an outer groove, and a rubber mallet to tap the back of the handle to convince it to rotate the rest of the way. But, I like the official Halboyles recommendation.
