gfunk1234
Aluminum Door cards
29 posts / 1393 viewsLast Reply
Finally got around to getting mine mounted.
Just temporary, I'm going to paint the vinyl on the upper strip and armrest, as well as the bright green clips.
I used 3M spray adhesive to glue the vinyl to the metal top strip and then cut it flush so it looks a little nicer.
Fit is pretty good, I had to re-adjust the chrome piece on the upper strip so I could slide the door card over to the right to get the holes to line up better.
Also had to grind the holes for the armrest slightly, contacted the seller who said that I probably got a prototype piece and offered to ship me new ones, so it's good he stands behind his product.  I decided to just spend the 5 minutes with a grinder to get it to fit.
Overall, I'm happy with it.
4 hours ago, gfunk1234 said:
What do you mean by bloated?
At some point under the previous ownership the door cards got  wet and bloated at the bottom, so I purchased the plywood version from Dave. Pre-drilled with all the holes just ready for me to slap the skins on them. The end result is beautiful!
