Des
73 base Verona 2002 What!?
18 posts / 842 viewsLast Reply
You drove home from Revere [emoji905] Beach and the L[emoji837] LIGHT! Lektrik!
So I looked today in the Garage at all of the connections————-Alt. Bat Cable,
And [emoji50] wow! No Alt belt on the Alt and nowhere in site!
Question? I drove 10 miles in the heat
home...... did I screw up things?
Can I drive it to my buddy’s garage 8 mi with no belt?
Sent from my iPhone using Tapatalk Pro
If you already drove for 10 miles without it overheating, after letting it cool down and charging the battery for a few hours you should be ok for another 8 miles but it's not that hard to get a new belt and install it.
Yeah, car runs off the battery, no?  Alternator charges the battery.  It is pretty easy to install a belt...
That thing is red.
When are you going to make some more videos?!
What did the temperature gauge do? Interested as to how much natural circulation there would be in the engine without a water pump.
That IS red. Holy Sammy Hagar! I like it!
10 miles without a water pump and it didn't seize?
huh.  New one on me...
I would be nervous starting the engine without it.
has used lots of different things as a temporary belt-
5 wraps of nylon string works great.
I once went 25 miles with a Chevy 305 in 90F weather with a bunch of block sealer in it before it overheated and died and it only died because it fried the electronic ignition.
I once went 30 days without a beer...
  • Haha 5
Crap.  I didn't even thing about it having the water pump and the alternator on the same belt.  Maybe I should stop offering advice before the first cup of coffee.
The gauge is been broken! So
That thing is red.
I will get on it. Thanks for the inspiration
I’m trying to order belt on Amazon any leads to what belt you would buy?
Tomorrow!! Is a good thing 73 base. Thanks Dez
Hi there! What Fan belt is the one you suggest. The are all so imported and I want a good one. Last time I bought off the net? Super confused [emoji2371]. Thanks man
Have you checked to see that the pulleys are aligned in a flat plane, allowing the belt to run without distortion?
The alternator is mounted using rubber isolating bushings, to insulate it from engine vibration and the bushings get soft and distorted with age.  That moves the pulley out of alignment and the belt wears out faster.
A vendor like Blunttech will have the new rubber bushings, (if you need them) as well as the belt.  If you call them I'll bet they could even pull up the part numbers for the required pieces to freshen up the alternator mounts.
Some people use polyurethane bushings instead of rubber, so they last longer.
