Sign in to follow this
roman.lysiak
Low beam relay location
5 posts / 309 viewsLast Reply
Do you guys know where the low beam relay is located. My high beams work but not the lows. Interior dash lights function so it’s not the switch.
Roman
What year is your car?  I know the earlier models have no low beam relay, just the high beams have a relay.  Check your low beam fuses and wiring/connectors to the headlights.
Six fuse cars have no headlight relays at all; 12 fuse roundies don't either.  Only squarelight cars have headlight relays, and only for the high beams.  On six fuse cars, the headlights aren't even fused!
If your low beams don't work but your high beams do (and you have a roundie) I would suspect the high/low beam switch.  It's either internally fried, or (if you're lucky) just needs cleaning internally.  Spray contact cleaner may cure the problem.
