Sign in to follow this
bianchini
Clutch master grommet PN?
5 posts / 202 viewsLast Reply
Hi All,
Does anyone have the PN for the grommet for the hardline that goes from the Clutch master up to the reservoir? Also, what is the trick to installing the line and the grommet without ruining the grommet....
Attached is a photo of the exact grommet I am referencing.
Thanks!
I believe it uses the same grommet as the older style brake master that used the smaller grommets (17mm outer diameter, 8mm inner diameter).
That part number is:  34311103205
The trick to installing the line is to have the clutch master out of the car when you install the pipe.  That's probably not what you want to hear.  Hopefully someone else knows a "better" trick.  Good luck
(edited)
I happen to have both a new clutch master and some of the 34311103205 grommets on hand.  I just verified that the grommets are the same as what came in the new clutch master...  But what do I know?
Edited by JohnS
