Sign in to follow this
djminkin
Wheel construction help.
7 posts / 419 viewsLast Reply
Hi everyone building a set of wheels from my centers I have and the builder has asked for the following info on a stock 02 no flared fenders. I don’t have access to my car to measure. Maybe someone has done this before?
From the brake hub where the center of the wheel meets go outwards to the edge of the fender
From the brake hub going inwards until hitting the strut
Please do both front and rear
Hi Danny, that is a very theorhetical approach.
Because the Diameter (of the wheel / tire so it doesn't hit the spring)  as well as camber, Hub and Brake Disc (Turbo hub adds a lot) is missing in requirements to give a number.
(edited)
Well it’s a Alpina flat rim that will be built up to 15”. These are the measurements he asked for in order to make the width for both sides.  The car is a ti with the original suspension and brakes
Edited by djminkin
(edited)
so in other words the question is which size and offset of 15" wheels (with which tires) will fit a standard body
With size and Offset you've got the dimensions
Edited by uai
He knows I need a Et25 offset but I guess he needs these dimensions to make sure the wheel doesnt rub.  Hes telling me can do a 8" wheel with a 2.5"-3" lip.  I dont want it to look like a Japanese car just tasteful with a nice lip on it.
With an 8” rim that has a 2.5”-3” lip (although I’m not certain how you’re measuring that lip), it certainly seems that you’re going to be rolling fender lips and pulling fenders. I think the “ti” behind the “2002” says much more about your car than the largest rims you can fit.... ?
Best regards,
Best regards,
I agree I don’t want something ridiculous and I definitely don’t want to roll fenders.
