jtgillsteamboat@msn.com
Replacment handbrake handle
3 posts / 337 viewsLast Reply
I'm looking for a replacement handle for the handbrake in my 1976 2002. With an M20 engine and 5 speed transmission, the centerline of the shift lever has moved a bit to the rear. I can modify the console to keep the shift lever centered in the shift surround but by then, the button on the end of the handbrake handle contacts the back end of the console...guaranteed to pinch your thumb when you release the brake. The current handle is 16" long from the centerline of the pin holding it in place to the end of the button and the operation of this cable system is fairly simple. But I can't find a cable operated replacement handle in the 10'-12" length range. Any ideas?
