MrAdams
NEED: Flag Mirror Bracket
4 posts / 156 viewsLast Reply
I recently discovered my mirror mount bracket needs replacing ( closed my door, mirror went flying ) luckily the mirror is OK!
Does anyone have a bracket available? should like like so...
it is NLA or I would order it new - $11 :(
let me know if anyone has one - and how much
thank you!
Adam
Happened to me too but I was able to fix with beefier retaining screw. I used a 10mm bolt (or one with similar threads to stock set screw) removed the head with a dremmel, cut a slot for the screw driver. I recall the modified retaining screw was slightly longer allowing for a tighter grip on the mirror stem and this setup is good as new.
Sent from my STH100-1 using Tapatalk
