agave67
‘67 Lemons 02 -> Clean ‘68 shell
2 posts / 475 viewsLast Reply
https://www.bmw2002faq.com/blogs/blog/387-my-lemons-1967-bmw-2002-revival/
I have a blog , but can’t access it through the app , so here is a new topic on a under a different forum . I picked up sight unseen a car from idaho I will now use as a donor car to this clean shell i picked up . 1968 2002 that has a tube front and a full cage setup , blasted and primed with zero rust . Progress to be made soon with it , such as repair of swiss cheese and will have to add the door from my donor car on since it is crunched on the new shell , in a spot . The m10 is out and I will be doing a 5 speed conversion and stroker build on the m10 . As for the body i hope to go for an OEM silver paint . It is cut out on the quarter panels for Alpina Pigcheeks which came with it , along with rebuilt steering box , f+r subframes reinforced/ with camber adjustments , lightened and powder coated pedals , brake backing plates with holes cutout for ducting . I have alot going on rn as i have my e30 awaiting an m52 swap in my garage currently , plus i have until the 30th to get the donor car out of my garage , since the new shell is in storage .
048a97f9423d760683500aa2f9e8c095.jpg&key=af17685b6f3e84ea3821fcec34c39b45361a526dd347163bec43582c0a7ea60d
8b5e2c7752c17aeb2f3d279b2a8431ed.jpg&key=12270b4c2cf461b893fb8379f36aa10f1c962324d9a49df4b488d17c5b27a104
582b03cbaff80cf209a11ab0bf8d763e.jpg&key=ac627daa6aa8312518ac92ba8fad796d93c793b3138086d293122ed46d8cfb45
Scored some panasports as well.
192e71cfa2b4b663768359b221669fe1.jpg&key=c77e013492f138978a7534853f3ecdd12c1446b6fc36a2434d6e02ef625b0ec4
Also have a set of 45’s , Italian ones . Cast air cleaners , and an oem manifold . I have to salvage a big list of stuff from the donor car :
M10
Dash
Cluster
Diff
Driveshaft
Pedals
Brake booster
Door catch
Trunk hardware
Wiper assembly
Hood open/close hardware
Doors
Etc.
