Weber 32/36 air filter ? will the larger filter fit under th
I don't have the answer, but a possible solution would be to test it. Gum might work, plasticine, Playdoh, or clay would probably be better. Oil the hood above the mound to keep it from sticking. If there is insulation up there, it will probably make this test worthless. Be sure to drive hard and do a good launch from a stop to torque the motor over.
hth, hope all is well too!
David
