Whaledriver
Overdrive choices for a 2002
7 posts / 386 viewsLast Reply
Has anyone considered an alternative installation of a universal (Gear Vendors) electric overdrive unit vs a 245 five speed for their 2002?
Yes, but after looking at the unit I could not figure out how to mount it without having to make major modifications to the transmission tunnel to make it fit.
It might be just as easy to use a Porsche 944 transaxle and move some of the weight to the rear axle while you are at it if you are interested in some serious fabrication.
In Europe they used the 3.45 diff on the Tii, but the US Tii got the 3.64. The 3.45 is about 5% taller. So you will gain top speed at the expense of a little acceleration. It's a lot cheaper than installing the 5 speed overdrive 245 trans, which is not ideal for the 3.64 stock diff since 5th is a bit too tall. That is why most people who install the 245 overdrive 5 speed also install a 3.90 diff to bring down the overdrive from 18% to about 10% in comparison to the stock set-up. I use the 245 with a 4.10 diff which brings my overdrive down to about 7% compared to a stock 2002. BMW offered the Close ratio 5 speed as an option on some of the tii cars equipped with the 3.45. This is probably a better way to go than using the 245 5 speed overdrive coupled with a 3.90 or 4.10, as it gives you better gear spacing in 1st, 2nd and 3rd gears while 5th serves as an overdrive in comparison to stock gearing..
I use a 240/5 Speed with a GPS Speedo, much cheaper than a 245, mated to a 3.90 LSD
206677230_5Speedconversion(5).thumb.JPG.3c7851ef64368fd1c6b4199b8fd7b511.JPGIMG_0679.thumb.JPG.25174e20c30a2fa83f26482fccce85ea.JPGIMG_6017.thumb.JPG.bd6728b30b9eafd01179a00a2cf5065e.JPG
You can also get a 3.45 gearset out of an e36 318 with a manual transmission.
Those are pretty easy to find.  It fits better into the E21 case, tho.
Byron, I HAVE a 944 trans- you may as well get the Audi version, it's the same thing
just with a weaker 5th.  Right down to the bellhousing and starter mount.
Parts cost a fraction of what the P- car parts do, tho.
One of these years, I'll find something to use it in.  Just...because.
@TobyB
I actually have an e36 diff rotting in my shed, and a 4-speed driving  a 3.90LSD on my tii. I’d like to get the revs down without going to a 5-speed. Can you indicate any instructions on changing out the gearing to get the 3.45?
Unless you're particularly adventuresome, yes:
Take it to a diff shop that does BMW diffs regularly.
It's not an easy DIY.
I do them for the race car, but they'd be awful noisy in a street car, usually.
