PG7202
Tii motor value advice
12 posts / 352 viewsLast Reply
(edited)
I've got a complete '71 tii motor still siting on the subframe pulled from a '72 standard that i scrapped about 8 years ago.  It came out of my old '72 standard car that had a swap when I bought it and I always planned to put it in to my '69 but never got around to it.  The motor ran strong and still has good compression.  It has 10:1 pistons and reground cam and I've kept Mystery oil in it but has sat this whole time.  I've got someone interested in the motor and may sell it but can't really value it.  I realize it can all vary depending on unknowns but haven't spent much time on the boards since the early FAQ/roadfly days and don't know if it's $1,000 or $3,000.  Any advice is appreciated.
Edited by PG7202
$2000 +\- 500 depending on condition/completeness.
Swap into a std car per OP.  Includes injection system, manifolds, etc.??? or converted to carb??
The motor is complete with the pump, injection system and all the other bits and pieces.  I cut the nose off the donor car and dropped the front subframe with the motor still attached.
You might mention the VIN/mtr #, just in case the original car is still around. In that unlikely event, the mtr may have more value for the original car Owner.
Yep, posting the VIN and pics might help.
Sent from my SM-G930V using Tapatalk
Here's photos of the motor.  The vin is 2762038 (1972 tii).  I do have the other two intake runners they are in a different box.
Thanks again for the help.
Thanks for the VIN. Unfortunately I do not have a record of that car, but, you never know, someone on the board might know of it.
(edited)
2KUSD for the motor, looks like uprated suspension there too, nice turbo type fat antiroll bar and vented brakes
Edited by dlacey
(edited)
VIN 2762038 should be a June 1972 car (perhaps June 21).  The U.S.-spec tii’s initially switched from 121 heads and plastic intake runners to E12 heads and aluminum intake runners at VIN 2761944. But — for whatever reason, e.g., parts shortages — BMW (temporarily) switched back to 121 heads and plastic runners at VIN 2762015. So I expected VIN 2762038 to have a 121 head and plastic runners — it certainly does not have plastic runners. Either the reality of the switches to and from E12 heads was more complicated than suggested by the parts manuals, or this particular engine’s runners, and possibly head, were swapped out post-factory.
Regardless, none of this makes any difference in the engine’s value!
An engine overhauled by an unknown party, at an unknown date, an unknown number of miles ago, and which subsequently sat around for eight years is a bit of a pig in a poke, in my opinion. But the presence of a complete injection system — even if it, too, is a pig in a poke — partially offsets the engine’s vague current condition. So I, too, could imagine $2,000 for the complete engine with ancillaries.
Edited by Conserv
