Summer-Izing for Hot SoCal with A/C - Pic Heavy
chargin
Great write up, love all the pictures. Just for clarification my Bracket does not require the lug the you show to be drilled out. I have seen people that do not have the top two attach points use that lug as a third position to secure the bracket.
57614929_2245938558787863_8852406369945387008_n.thumb.jpg.7444b4d9aa4c483e15dcc0fb743240d3.jpg
Just FYI.
This is the Clardy/ hobiedave bracket installed on my 72 -M10
1972-2002 "polaris"
2000 M5 "Dieter"
2004 330i "ILKA"
Ironically I sold your bracket when I bought the ICEAC kit because it takes a different Sanden mount, obviously I should have fit it before I sold yours ?
I don't take myself or opinions Seriously
My 4th 2002 and the first set of Square Tail-Lights
See the 4 versions of my 2002 project here: SoCal S2002 | Facebook
Update: I added this Fuse Buss up front to get rid of all of my inline accessory fuses to clean up the harness area which includes the 2 new A/C 30 amp fuses
Just FYI.
Can I clarify something about the bracket install?
The left hand bolt that goes through the engine mount has a washer installed underneath to space the bracket out?
So, in layers from the bottom, we have: block, engine mount bracket, washer, AC bracket, washer and bolt head?
 I am going to try and install this over the weekend, so the timing is excellent here!
rtheriaque wrote:
What are your two fuses for?
Evaporator fan and condenser cooling fan?
Dave, your product is an excellent build quality, in the future maybe you should add that additional hole on the bracket?
Seems like it would be easy enough for those that are missing the 2 top threaded holes
1. Radiator Fan and Compressor Relay
2. Evaporator Fan Relay
Interesting. You use a separate relay to drive the compressor clutch?
Most other arrangements sees the clutch switched by either the evap fan switch or cycled by the temperature switch directly.
Radiator fan & Compressor - Engine bay parts
Evaporator Fan  - Interior Parts
On 5/28/2019 at 1:02 PM, chargin said:
Update: I added a switch to turn off the compressor, this way in stopped traffic I can run the additional electric pusher fan for cooling without engine load. Worked great in 83' traffic.
I did that the other way. I added a manual override to power the condenser fan.
I should look at finding a stronger blower motor for the Frigiking, though through the recent 100 degree days here, driving the car has been pretty tolerable. Still looking at ceramic window tint to  block heat. Maybe https://www.amazon.com/gp/product/B07CT59N9K  but I haven't pulled the trigger...
Nicely done!
Cheers,
Ray
Simeon,
I installed mine with the Moutor mount first then the A/C bracket then washer and bolt on top of that on the left side. The bolt on the right needs a washer placed behind it the thickness of your motor mount ear to keep the bracket level at the bottom.  Hope that helps.
Dave
Edited by 02hobiedave
1972-2002 "polaris"
2000 M5 "Dieter"
2004 330i "ILKA"
Chargin
The hole is already in the bracket but it is in such a place its hard to mount a bolt in that location unless you modify the bracket. Its the half moon shaped cutout at the 90 degree next to the weld. Dave
1972-2002 "polaris"
2000 M5 "Dieter"
2004 330i "ILKA"
1 hour ago, 02hobiedave said:
Chargin
Wow! A++ on your fabrication!
  • 7 months later...
Do you recall where the position of the evaporator housing hole for the temp probe?
I've already mounted my evaporator and can't find it.
The glove box was being blocked by the new console plastic so I added this 2-1/2" aluminum bracket to pull it in 3/16"
57611737_2244080178973701_975524949961736192_n.thumb.jpg.44686870c3f1a2f9f3fde548f548c476.jpg
With the cabin done I drilled and pulled the harness, plugged it all in and ran the A/C Blower fan without issue.
It blows VERY hard, like a modern car.
'98 M3
'74 2002 Touring
'01 750Il
'96 B3 3.2 Touring
