Just strait up can't figure it out. $50 reward offered.
Ok so here is how I kinda Gerry rigged a quasi solution.  So essentially I fire about 130% more fuel on decel, when the throttle is less than 2%.   This stopped the popping on decel, which is huge.
The second thing I did is jack up the fuel just below where it was going to idle.   So when it does it's thing and goes lean 2-5 seconds after it hits idle, it gets more fuel (and timing) when it tries to stall.
I have driven it for a couple of days like this, and so far so good.  It definitely doesn't want to overrun on decel.  And if it tries to stall it dumps fuel and timing to get it back to idle.
The picture below illustrates the type of table I run on less than 2% TPS.  I changed it a bit last night, and moved the entire curve to the right in order to get some more resolution below 1000 RPM and be able to ease into the extra fuel little bit less abruptly.
Not a solution, but a patch until I can get things organised for the switch to a standalone ECU and the 3 series intake.
"Goosed" 1975 BMW 2002
