RussTii
Sold LSD's, Tii engine
10 posts / 762 viewsLast Reply
Price: $800
Description:
Pair of E21 LSD's. Early unit has 4 bolt side covers, 8 mm output flange bolts, 3.64 ratio with 39 # breakaway. Both units are not rebuilt, no noises, good backlash. Late unit has 6 bolt side covers, 10 mm output flange bolts, 3.90 ratio with 37 # breakaway.  $800 each. Pickup in Lawrenceville, Ga otherwise shipping at buyers expense. Assume 65 # in a wooden crate shipped via FEDEX GROUND.
Tii engine # 2761368, 72 date stamped block, 121 head. Includes pump, injectors, TB, Plenums, Tii alt, airbag, exhibit manifold, 008 distributor, water bypass tube. Good crank, turns over easily, needs rebuild $1000 complete.
87 M3 radiator $100
5 hours ago, wheelieking said:
I might be interested in the 3.91 diff.  I have a 76', but my rear diff cover doesn't match those and i don't know what size my output flange bolts are at the moment. Would I just use my current rear diff cover?
Yes, those are e21 rear covers. You would replace the e21 rear cover with the rear cover from the differential currently in your ‘02. Done!
