No turn signal return with Nardi steering wheel hubs?
Thanks to those who responded.  I have the new parts I need.  However, I'm still not clear on the assembly.  Should the snap ring, which is item 6 on realoem be press fit into item 7, which is called the 14mm ring on realoem?  It seems like that is the only way to hold the ring in place or is everything just held in place by compression once the wheel is on?
