Weber 32/36 DGAV idle problem
I assume it's a water choke, because it has a hose coming from the
manifold and one from the block. Anyway, this is a newly aquired
vehicle, so I though I would set the carb to specs according to the info
from redlineweber.com. I am sort of a carb moron, so I will try and
explain what I did. I turned (what I think) is the idle mixure scew (back
bottom corner of car, fairly large scew with a spring facing up at an
angle) all the way in and then back it out two turns. Then I backed off
the idle screw (moves the cam on linkage?) till it barely touched, then
tightened it a turn or two....this should be 'factory spec'. Car started
up, but didn't' even come close to idling. I have to really give it some
gas. Before I messed with it, the idle mixture scew was turned out 8
turns and the idle linkage scew was much more than a couple turns
past where it touches the cam on the linkage.
I guess my question is, am I doing this right, and if so, any suggestion
of what is wrong. Oh, all adjustments were made when the car was
warmed up.
John, First off, you are doing it right.
But keep in mind those "factory settings" of 2 turns out on the mixture screw is really more of a *starting point* - if the car wont idle, try backing it out, 1 turn at a time until it does - shouldnt be more than 3 or 4 turns. If it is many as 8 then you probably need to determine what size idle jets you have. Those are screws on the left and right side of the carb toward the top - you unscrew them and the jets come out - tubes with little holes in them - they have a size on them - then you need to confirm they are the right size...which is determined by your altitude, set-up etc but if you do a search on weber jetting I'm sure you can locate some recommendations - basically if the jet is way off you potentially would have to compensate with major adjustments - hope that helps, Aaron
I may have the exact terminology wrong (I'm a bit of a carb moron as well) but I had a similar problem with my 32/36 (i.e., no idle despite adjustments) until we noticed a small switch near the carb base facing toward the passenger side of engine compartment. We ran power to it and bingo--immediate idle. This may seem obvious but it wasn't to us when we set up the carb. Good luck!
you must set the dwell and timing with a light to 1500 rpm , and no vacuum to the distributor if fitted. Reconnect vacuum hose(s) when done.
now go back to the idle speed and idle mixture adjustments.
It is an emission device that keeps the engine from running on after shutting it down. It only requires a switched source. When key is on, there is voltage. When key is off, there is none.
Hope it helps.
