Any tips for installing rear qtr windows and door glass?
URL: http://im4bmw.freewebspace.com/index.html
Now that Hugo's front & rear glass is back in I plan on tackling the side glass this weekend. Any tips from those of you that have done this before? Especially regarding installing the qtr window trim pieces that have 4 rivets at the window opening at the qtr panel...
Words of wisdom always appreciated...helps avoid screw-ups, hopefully! :-)
Have a great Holiday!
John
'72tii "Hugo"
It was partially due to the fact that the rear quarters had been replaced
and there was just barely room to get the seal in. It was really tough
(talking about the part that is adjacent to the rear window.) I had one
wrinkle in the lip of the seal and it always leaked. I doubt you would
have made that mistake but just thought I would post just in case. The
next time I did it there were no problems.
The door glass on the other hand really takes some time to get aligned
correctly. Budget a bunch more time than you think to get it all lined
up as (for me at least) it took a lot of trail and error to get the various
adjustments exactly right.
URL: http://www.rccarcrafters.com/interior.htm
I'm SURE you have stainless rivets and new cotter pins! I used a dulled plastic knife to work the qtr gasket in around the upper part and under metal trim. Like the door gasket, start with corner of the window gasket in place. Don't drop the side window fumbling with those tiny screws!!
It'll be great!
John in VA
