Battery Tenders
SydneyTii
I also have Battery Tender Juniors connected to multiple vehicles all the time over winter without disconnecting batteries, 2 cars and a motorcycle, sometimes a mower too.  Probably for past 5 or 6 years at least.  I have quick disconnects on most where I just plug the wire into the grill without popping hood.  I have a few cars left I need to install that on, though.
I believe I've started them with tenders connected many times, but usually disconnect the wire just because I want it out of the way so I can drive it.
Never any problems, not sure why you'd make more hassle for yourself.
Bring a Welder
I have two Schumacher ‘Battery Companion’ 1.5 amp trickle chargers that I use on my 1980 Mercedes diesel and my BMW Z4.  I leave the batteries connected in both cars, I connect directly to the battery positive post on the benz with the ground wire from the charger clipped to the chassis.  On the Z4 I connect the charger to the jump start posts, if you go direct to the battery on that car the check engine light supposedly comes on.  I’ve used the same charger on my Tii in the past hooking it up like my benz without any issue.
'03 BMW Z4 3.0i
’89 BMW 325is
'80 Mercedes-Benz 300SD
'20 GMC Sierra 1500 SLT
