Car wont start
So recently I had a friend help me adjust the carb and get all the fuel set up right, but the car was still buckign around while doing anythign other than idle. So I checked the plugs which turned out to be autolite and gapped at .045... which is WAY off so I swapped those for some correct bosch ones, and put in new points (dont have a dwell so I had to set it to .017inch gap) greased it up (first time ever workign with point style ignition) and tried to start it. Car cranks, but wont turn over now. When it started fine before. Any thoughts?
are you getting fire at the plugs?
are you getting fire at the coil?
double check all your connections?
give us some more info...
Got spark? That's what you messed with last, so see if it works.
Use only a TINY amount of grease on the rotor shaft lobes only. Any grease on the points and they won't work. Add a drop of engine oil to the felt pad inside the top center of the rotor shaft to lube the advance mechanism.
Is the point gap sparking? Did you unplug the coil to work on it? Check all connections.
Check your timing.
-Jerry
