Coastalcrush408 336 February 12 looking for a manual pedal box to swap my auto over to a manual. Thanks, Max Share this post Link to post Share on other sites
stephers 67 Wednesday at 05:50 AM You will also need the brake fluid reservoir that has the extra nipple on the side for the clutch hydraulics, the pipe that feeds fluid to the master cyl, a master cylinder and hose to the slave as well as the slave. Hope that you are putting a 5 speed in after all this work Good Luck 1 Share this post Link to post Share on other sites
Coastalcrush408 336 Wednesday at 04:24 PM (edited) 10 hours ago, stephers said: You will also need the brake fluid reservoir that has the extra nipple on the side for the clutch hydraulics, the pipe that feeds fluid to the master cyl, a master cylinder and hose to the slave as well as the slave. Hope that you are putting a 5 speed in after all this work Good Luck I’ve gathered most of those items already. Planning an m42 swap. Thanks! Max Edited Wednesday at 04:26 PM by Coastalcrush408 Share this post Link to post Share on other sites
shermanmartinez 39 Thursday at 04:58 PM I have a fully restored pedal box. Powdercoated box and pedals. All hardware gold cadmium plated. New bushings and springs throughout. Located in Vacaville,CA. shermanmartinez at Hotmail dot com Share this post Link to post Share on other sites
