ray_
lean at 4k under light load
31 posts in this topic Last Reply
Howdy,
I didn't do a search  :) AFR go 2 points lean at about 4000-4200rpm under light load only.
Carb is jetting fairly stock-ly and performing well at other loads and RPMs.
Timing is 123.
Cam is a very mild Schrick  and compression is 9-ish to one. Stock exhaust other than tii manifold and loose baffles in center muffler (to be remedied tomorrow).
Usually  to compensate, I  just go faster. :P
TIA,
  • Haha 1
(edited)
There ya go. No need to get your hands dirty.
Edited by jimk
  • Haha 1
How lean?  Sounds like a good place to be lean for fuel economy...
16 ish
1 hour ago, ray_ said:
Howdy,
I didn't do a search   AFR go 2 points lean at about 4000-4200rpm under light load only.
Timing is 123.
TIA,
Just pull the parking brake up a few clicks. That should keep you from experiencing this "part throttle" you speak of.
  • Haha 1
I could probably disconnect a plug wire... 😋
Those are the big ones that go to the round sticky-upy thingy? But which one to unplug?
16 ish
Remove the AFR gauge and all will be good.
  • Haha 1
Yeah I  know :P
It will stumble there, getting back on the throttle.
1 hour ago, roadhog0 said:
16 aint that scary at light throttle light load. Sounds like a Weber 38. Play with the emulsion tubes.
Yeah, true. It does stumble a bit there though.
I tried F6 emulsion tubes and saw no discernible difference. Is there a guide to emulsion tube swapping?
Cheers,
3 hours ago, Guest_anonymous said:
try the 40DFAV again
I need to  sell that.
Do you want it? :)
I'll start with the centre one.
:P
