dlacey
Gearbox Numbers
15 posts / 931 viewsLast Reply
On my turbo 4sp there's a number stamped on the bell housing on the flat section adjacent cylinder head:
Is that meaningful?
(edited)
Just the Getrag serial number. I don't think BMW recorded them. Although they did for the earlier cars like when they changed from the Porsche to Borg Warner synchronizers.
Edited by jgerock
I don’t know if there are any specific markings on the Turbo 4 speed that will tell you if it is a real one.  The easiest way to check is to pull the output flange and compare it to a standard 2002 one.  The splines on a Turbo 4 speed are 2mm bigger and a standard flange will not fit.
I found that the /3 refers to the 242/3, a strengthened box.
Mine is 000918 / 3 which to me is the 918th box and is kinda close to the SN of 1053.
Any other correlations of the SNs of transmissions and VIN?
I have not found where this transmission was used in any other application, BMW or otherwise....
Mine fits that pattern...gearbox 708 in chassis xx732.
Thanks...I a minded to change a few oil seals if it's not too difficult. Otherwise I will just drive it & see how shifts/sounds.
My box had about 90K miles on it before a shim on the input shaft got torn up.
As always, for high mileage transmissions, I recommend buying the parts now for future use. I am trying to find more of the special (more robust) input shaft bearings...split outer race with brass cage which is good to 10K rpm. Be prepared to spend upwards of $2500. for parts including the layshaft. They are not the same as the standard 242 4 speed.
And too, i use XamaX gearbox fluid formulated and sold by Precision Automotive Research which cures all of the balkiness of the synchromesh. Been using this for over 20 years and can vouch for its performance in Getrag transmissions..
Pm me if you need help.
I guess those numbers would make sense combined with the cars they are in because not every car was a 4-speed.  Interesting.
And I would surmise that the transmission number should be less than or near the SN.
It would be interesting to know how many were made.........
So we might guess that 24 of the first 732 cars had CR 5 spds, and a further 111 of next 321 cars had CR 5sp... of course many assumptions here, but it looks like the alternative gearbox got more popular...but if it continued at that later rate then about 338 out of 1672 cars got the 5sp....meaning the Strengthened 4sp is a very rare box with only ~1330 ever made.
I’m sure it is more rare than the 5-speed given the 5-speed was available in cars other than the turbo.  I’ve read there are a couple different versions of the CR box available in the Turbo (according to the m registry) but I’d have to see both versions to know for sure.
Edited by wkohler
(edited)
But isn’t this premised on the assumption that BMW did not make one single spare or replacement transmission? That’s an unrealistic assumption. Yes, many (most?) transmission failures are probably rectified with individual parts — synchros, output shafts, etc., — but I bet you could buy a complete new turbo 4-speed during and for a few years after the turbo production era.
Best regards,
Edited by Conserv
Sure, I bet there were replacements, cause they are in the Orange books, so it must be.
And for the real minutia, what would  have been the serial numbers on those?
And too, perhaps they were used on other brands and models of cars.
The thing of it is, many of the Turbos still around are technically garage queens and just don't have the mileage on them to warrant a rebuild. It took me over two years of searching for all the parts, because "it is just the same, only different".
Can you provide a link to what you mention above as I am having trouble finding it.
Sure, They are the only one since they developed it and have it blended to their specification.
don't let the goofy website sway you.
http://www.precisionautoresearch.com/
Precision AutoResearch
901 Hillside Drive
Bensenville, IL 60106  USA
(630) 766-4402
[email protected]
Speak with Dave Sr., David Ph.D. or any intern....
