machine shop questions
hey everyone, i got my "new" 121ti motor torn apart
(thanks for the vid kris!) and am getting ready to
send it off to the shop for work. am i forgetting
anything major? this is my first rebuild so let me
know if i'm a dumbass.
-hot tank block/head and all accessories(timing
covers, oil pan, valve cover, etc.)
-enlarge exhaust to 46mm (it's got 44's)
-measure everything to see if it's in spec (main
bore, cylinders, pistons, crank, head height,
rockers/shaft) and replace what is worn
-install new valve guides and seals
-balance bottom end
anything you folks can add? all input is
appreciated!!!!
Unless you have reasons to believe otherwise, you should count on new pistons (and having the block punched).
My list. . .
Block:
Hot Tank
New Freeze plugs
Bore for oversize pistons
Head:
New valve guides
New valves (you're buying new intake valves anyway)
Magniflux to check for cracks
Have the head surfaced (just to be safe)
Check rocker shafts and rockers carefully for wear
Machine work:
Dynamically balance the crank
Recondition rods
New Parts:
New pistons
new rings (I like Deves)
new rod and main bearings
I wouldn't bother having the block decked or having the bearings line bored or checked.
John N
Also some places like Metric Mechanic sells a top end rebuild kit that
includes all the stuff in the top of the motor. Things like rocker arms,
valve guides, valve seals and a bunch of other stuff. Have the rods shot
peaned and then resized and use new rod bolts. Don't forget to spend
money on ballancing. Some people don't think it's worth it for power
but I can tell you that it's worth it for a street engine.
john
Take your freeze plugs out before you take the block in as they will charge you to remove them. The blocks hot bath and the solution for the head are different and the heads cost will be more expensive to clean. In Denver cost of head rebuild varies greatly. I have used a shop that does a complete rebuild including disassembly (you furnish parts) for $300. As far as I know you cannot magnaflux an aluminum head. It requires a pressure check which I highly reccomend. Have the crank checked and dont go borderline. Have it ground if your even close to oversize. When you get the block back wash out all the water and oil passageways as the machine shop will do 75% percent of required. Youll need a cylinder hone before reinstalling pistons and if your close to overbore bite the bullit with new or used oversize....Good luck
