Does one run Flex a Lite with stock fan or as replacment?
My '74 is running a bit warm when I drive under 30mph if the
outside temp is 85 or more, but seems to be fine at higher
speed (or when temp is below 85). I am looking into an
electric fan (not that I know for sure that this is the problem,
but from what I have read seems possible???).
Sounds like a lot of people here have added the flex a lite
130, which I might try, but I'm wonderig why use a pusher in
front of the radiator - doesn't this block wind flow from
driving? Also, does the location in front mean that I should
run the FAL with my stock fan or can I disconnect the stock
fan (more power?)?? (sorry for the rambling post - a little
confused)
Thanks in advance for the advice!
Andreas
'74 Chamonix
URL: http://www.livejournal.com/users/jennaishealed/
in there... the stock cooling system *SHOULD* be adequate for a stock motor. even the 130hp tii uses the same little teeny 02 rad as the 100hp carb 02. to answer your question, the point of an electric fan is to eliminate the stock fan for quieter running and more available power. it probably takes about 5-10hp to spin the stock fan at 6000rpm (maybe), so for about $100 you get that little boost of available power. it wont block flow enough to counter the effects when the fan starts blowing. use a thermo switch set to about 180degrees, with a good stock rad (getting yours boiled is about $45, but i paid $18 for my good used 320i radiator). you might want to upgrade the stock alternator if you havent done so already. easy upgrades abound....
-Rob
From what I've read, there's not enough room to put an elec fan in place of the stock fan.
Many use an elec fan in front as a supplement to the stock for city/traffic conditions, or AC.
