rjm
Sold my 1975 bmw 2002 - on bay area CL
13 posts in this topic Last Reply
Price: $12000
Description:
Ive posted my car on CL -here is the link and some details:
Numbers matching car! Clean, well running bmw - new timing chain,new oil pump chain and tires! Crank seal /pan gasket etc all replaced at same time. New ground control springs (about 1" lower than stock) and koni shocks plus after market sway bar (rear) installed 12/2018. Rebuilt Weber 32/36 carb with manual choke. Compression 160-165 across all cylinders. Stahl header and IE SS exhaust system (All smog devices removed ) replaced dist with rebuilt early version. OE passenger side mirror. Runs and shifts fine. A/C removed and heater rebuilt. Doors and ignition use same key. All windows and locks work as they should. Radio works but is OLD - from 70s or 80s . Door panels NOT cut. All gauges work except odometer is intermittent - speedo fine. NO major rust- car was originally tiagra green now white " ok repaint" at unknown time - probably about 10 years ago. Solid car that is daily driven. Ugly late bumpers replaced with early style.
https://sfbay.craigslist.org/sby/cto/d/san-jose-1975-bmw-2002-smog-exempt/6810014369.html
