Do 02's have any overheating problems in particular
My new project car seems to run hot,temp gauge reads normal,but I touch the motor and I'm thinking HOTer than other motors.I don't have a thermometer to stick into the radiator,so I'm just curious if the 02's have an overheat problem.
My heater hose connections were leaking,so I by passed the heater core with some hose.The hose was kinked at the rear of the head where it went into the firewall,when I started the motor I got mega steam out the exhaust.I'm guessing that it was building up pressure in the water jacket when the hose was kinked,and blew water into the cylinders.I may need a head,anyone know where I might find a used or
rebuilt head.I'm just guessing it's cracked.
there are exceptions, but in general they seem to be just like
any car. Engines are hot to the touch and you can not trust
you gage, unless you know before hand it is working ok, and
even then... You know you have an overheating problem
when coolant starts popping out of the radiator cap, among
other things. The only 02 that had an overheating problem, of
10 I owned, was due to a corroded head which had reduced
web thickness betweeen cylinders, thus not allowing the
gasket to completely seal, sending water in the combustion
chamber and creating a rolling fumigator (is that a word?)
Check on this board main menu for vendors for rebuild, also
the archives, there are guys that can do it too.
It's not possible that your kinked hose would have caused your trouble. Think about normal situation when your heater valve is closed. In my racecar I've removed heater and blocked that hose totally. What could be possible is that when installing the hose you left some air in the system and it caused some local heat build up burning head gasket.
Tommy
some bug spray in your radiator and you've got yourself your very own mosquito fogger! I wonder if it'll pass smog tests...
(Raid-iator?...hehe)
