Mmathew
VAC Hybrid oil pan wont fit my s14 engine
11 posts / 651 viewsLast Reply
Hi guys,
I decided to go the route with the VAC hybrid oil pan for my s14 engine (M2 project in the works).
Unfortunately I have 3 issues:
- The oil pan wont align with factory holes for installation
- Oil pump pick up does not clear the bottom of the pan
- Passenger side motor mount does not clear the side of the pan
I have sent it back to the manufacturer (Moroso) and they have verified fitment on their engine block and it fits perfectly.
My question is:
Do certain S14 engines differ in specs? Why would this pan not fit my engine if it fits theirs?
Any help is appreciated.
I have attached pictures of Moroso's engine block test fitting the oil pan in question.
Thanks!
Pan bolt patterns are same with M10 and S14 blocks afaik.
(edited)
I have that pan, and while it bolted up to the block just fine, it did not clear my subframe.  Do you have the S14 oil pump pickup?  I first ran my S14 with a 2002 oil pan and had to use a 2002 pickup, which did not fit when I converted to the VAC pan. In the attached pic that's the m10 oil pump pickup on the left. It protrudes too far to the rear to clear the shallow rear half of the oilpan.
Edited by Ian
My hunch is that since this is a welded pan, the dimensions may shift slightly during welding if the welder does not pay close attention.  Perhaps this caused the mating surface of your pan to shift slightly.  In my case the pan bolted up, but did not clear the subframe or the motor mount bracket on the passenger side.  I like the pan,  but had to make accommodations to use it.
(edited)
Hey Ian!
I am using the S14 oil pump pickup but it does not clear the bottom of the pan. I have to remove it just to fit the oil pan on, and even with that the holes do not line up.
Thanks for your pictures, I appreciate your help on this!
Edited by Mmathew
Something sounds seriously wrong.  Can you take your old pan and line up the holes with the new pan and see where the new pan goes wrong?  I'm not able to look closely at your pan, but it does sound like it was put together incorrectly.  This is a welded pan, so a lot will depend on the skill of the welder and the attention paid to the assembly.
Hi Ian,
Yes the m10 oil pan fits perfectly on the S14. There must be something up with the manufacturer's block...
