Autocross Alignment
My '73 2002 is going in for an alignment monday. The car
has S.T. springs, Ierland hollow front sway bar, 22mm rear
bar, fixed camber plates, 14" wheels w/ 195/60 Yoko AVS
tires, all urethane bushings. I would like to get max.
autocross performance out of the setup. The alignment shop
has the ability to tweak all settings (caster, camber, and toe in
front; camber and toe at the rear). What settings should I be
aiming for? Any other tricks to do while we are there?
Front
-3.5 degree camber
1/16 toe
Rear
-2.5 Degree camber
0 Toe
Those are good starting points. Work from there.
steve k
