ddletendre
Crankshaft pulley replacement?
8 posts / 584 viewsLast Reply
Currently running the part #10 from the picture above (part number 11211263516). It has a cracked and chipped on it right beside the key slot. I don't fully trust it, and wouldn't want my woodruff key to fall on my timing chain!
Do any of you know about a replacement part that could work? OEM or not, I don't have A/C or anything.
Thanks!
Not quite sure- is this a WTB post?
Lots of us have lots of these kicking around- they're not a commodity.
There are 2 basic types- the big heavy cast pulleys, used in cars that
had accessories, (there are about 8 different varieties)
and the stamped steel ones from the ones that did not.  Might
just be the earlier cars that got those.
The E21 pulley is a 3- sheave assembly, but is stamped, and quite a bit lighter.
Also, if I recall, smaller in diameter, so it runs your accessories slower
IF you use 2002 pulleys on the water pump and alternator.
I have sawn off the front 1 or 2 sheaves sometimes for extra clearance.
I'm sure that voids the warranty...
(edited)
I believe the stamped steel (vs cast iron) pulley is still available for about $94.00 if that's a direction you choose to go. Used ones should be plentiful and super inexpensive though. I installed one of these on my last modified car to save a little weight and for aesthetic / simplicity reasons.
Link with part number below (item #3):
http://bimmer.com/bmw/showparts.do?model=2551&mospid=47129&btnr=11_2369&hg=11&fg=20
Edited by wegweiser
Wonder which model ran the two piece pulley (parts 6-9)?
That one would be handy for such things as toothed ignition pick ups.
The two-piece pulley is tii stuff. The keyed portion includes the gear for driving the injection pump belt. Note: tiis with AC had a second groove for the Ac compressor belt.
I installed the lighter weight steel pulley on my 69.  Got it used from a local 2002 owner and had it powder coated.
66F8080D-54D2-4B07-8340-C33F3CBDE5C1_zps
Do you know the exact part number for this pulley? I'm gonna be looking for them online and on local group (Quebec Canada)
I posted a link above, that has the part number, cost from Maximillian Importing Co, as well as a factory diagram, earlier. If you're not able to open the link, let me know. You can always e mail me directly at [email protected] (Attn: Paul)
