How difficult is installing a new headliner
caseywarren
1 hour ago, caseywarren said:
Anyone have any recommendations for places in the Seattle area
Patrick @midnightmotorsport should be able to take care of this for you. Website is being rebuilt, so not a lot there, but contact info is on the front page.
http://www.midnightmotorsport.com/
Brent
1974 2002 - Megasquirt and turbo
2018 BMW M2/ 2013 Porsche Cayenne Diesel
Have done this many times   It is not hard    Some advice from and old phart :
1   Iron the headliner before installing   Do not think you can pull out all the wrinkles you cannot.  Putting headliner in too much tension will come back to haunt you
2   After a bad batch of heat sealed pleats I run a stitch down every seam before installing   They don't make things the way they used to
3   Be patient.   Don't rush     Keep your hands and fingers clean with lacquer thinner   Be patient
4    Use brush on glue   I have good luck with Welwood and those 89 cent brushes from HD    Spray glue is way to hard to control    I have also used vinyl top glue too but that is hard to find in small cans
5   Be Patient and in a good mood    Keep your hands and fingers clean   Don't rush
6    Toby's advise is good
7    Use lots of binder clips to get it generally positioned all the way around, then start gluing on opposite sides, front and rear     Do small sections and do not pull too tight as you will end up with wrinkles in the corners
8   Final advise    BE PATIENT, keep your hands and fingers clean and don't rush    No need to hurry
If I can do it anyone can
HTH
HI,
  Just to add my thoughts.
Mike NC is right about each point.
i have only done two headliners and i
kept my hours logged. it took 32 hours
to move a good headliner from one car
to another, install time only, with sunroof.
the none sunroof car was a new panel
and it took 19 hours. i watched that video
from 32minutes until they stopped showing
the install. that was scary. i work from back
to front with both cars and for the sunroof
car i finish the hole before i get to the front
windshield frame. i actually use wood clothes
pins and binder clips with blue masking tape
on the inside of each to protect from marks and
damage. i also use the tape on the headliner
as a guide line when the clips come off for gluing.
all the correct edge protection for the sunroof
must be in place to protect the white liner.
finally i have never seen anyone try to install the
long rails and the center panel together, that looks
like a nightmare. get the liner in and set for two days
then glue, then leave it for two days, then install the
inner roof panel then finally the body panel.
it can be done like Mike says clean hands and time.
just like the the nuns used to say to me;
Be patient or become one!!
stone
stone racing co
phila pa 19123
Wow, after reading all these tips, you guys really have got me motivated to,
Hire a pro....
Hey Stone,
Sisters: Barbara, Anne, Anne Marie and Diomede, never really lectured me on patience, they just smacked me, or pulled the hair on the nape of my neck while directing me to the Vice Principal's (Brother Vincent's) office....not like I really deserved it or anything....?
Cheers!
1975 Malaga. It is rusty but runs. Just like me.
I've always thought a great name for a band would be "Nuns With Rulers."
  • Like 3
Les at Convertibles Only will do a good job for you.  It will be beautiful.
It may take a while, and it won't be the lowest quote.  It will be beautiful.
If he's still doing 'em...
These guys in Kirkland installed one my E9 sunroof car.  It turned out nearly perfect.
https://www.allcityconvertible.com
Among the things I won't even consider doing myself, this is high on the list.  By the way, because you need to remove the windshield and rear window to do this properly, it's a good time to check the condition of the gaskets and locking strip...and the glass,,, and???  The classic project creep.
Bill
1973 3.0 CS Nachtblau
1970 2002 Chamonix
1965 1800 Chamonix
Related question: Those of you that used professional installers, did you or the upholsterer contract the glass removal and installation?
Because I need to know if I have to do a two step process and become the next "Goggles Paisano" driving without a windscreen to the upholsterer....
I towed my car to and from the installer without glass because I removed the windshields myself and the engine isn't in the car. I can't even imagine driving without a windshield. Plus, it's winter in NY.
1974 2002 Tii-SOLD
1978 911SC Coupe
1988 Landcruiser
2020 M2 CS
Hire a pro....
Afterword, go out and buy a really nice heat gun as a "reward tool" as if you were going to do the job yourself.
You knew you wanted a reason anyway......
Thinking of getting a 12v version. I will need to have one on my face as drive to the upholsterer.....
  • Haha 1
