Early 1600 Driveshaft Flex Discs???
andyleonard
Went through some old receipts and catalogs for my Feb. 68 1600-2 which had the 3 guibo driveshaft.  I found numerous receipts showing part # 26 11 1 100 863 flex disc.  In an old Rocky mountain motor works catalog it shows that this is for a 2002 thru 68.  Since I don't have a 2002 I must have used these on my 1600.  I bought them from Maximillian Importing Co.  in 2002.
Ach! Another bargain from BMW! Only $187 each and 3 required.
Given all the 3 bolt flex discs in use by BMW/MBZ etc. is there an interchange known? 76mmx10mm. Any thickness will work as shaft has a slip joint.
Edited by andyleonard
All I can find is "original OEM. " I wonder what the resource would be to search ALL flex discs by size and see what's 76x10? This should be  $25 problem not $200.
Be easier to cut the 3 flanges off the shaft and replace them with E36 parts than to hunt these puppies down now and later.
Thanks Einspritz for tracking this one. It's for one of the guys on here.
OK. They are / were made by Jurid, from an OLD import car catalog.
Look to see if your 3 ear flange is the same as an E21.
the 6-bolt units were used on the '81-'83 manuals and '77-'83 Automatics. the size is 108mm O.D. x 28mm thick, 10mm holes.
26-11-1-225-624
Your quest begins.
45 minutes ago, West Palm 2002 said:
I got the same discs
Yep. That's the same part with the old part #. Each old-style driveshaft uses 3 of them. That's what we're looking for - just not at $200 each.
Soak those guys in Armorall for a day.
