Einspritz
Turbo Rear Wheel Bearings
10 posts / 711 viewsLast Reply
I am searching for the manufacturer PN for the 30 x 58 x 16 wheel bearings.
Searched all the catalogs for the usual suspects to no avail, FAG, SKF or any permutation by Schaeffler.
What I really want is the proper size but with the plastic inserts, not open.
Any insight? Cashel shows a picture of them but I can't get the PN, nor a cross reference.
Realoem cross references the bearings to regular 2002s and E21s.
Looks like this fit the bill. I thought it may be a stock photo, but the seller's other auctions depict different pics.
https://www.ebay.com/itm/Pair-Set-of-2-Rear-Outer-Timken-Wheel-Bearings-for-BMW-E21-320i-E10-2002-RWD/362510255773?fits=Make%3ABMW&hash=item54674b869d:g:WRsAAOSwjTtcFW9p:rk:20:pf:0
GL,
2002, Tii et.al are 28 x 58 x 16mm so not it; turbo stub axles are different, of course 30 mm.
e21s are the same 28mm axle, so no go.
I am looking for the bearing part number, not the BMW part number.
In that way I can then look it up and add the suffix to get the sealed bearing.
Now we're getting somewhere, however my bearings are FAG with a number of 527357, 62.28, A.B, F(?).B
so, the 537374 number is different. FAG doesn't have a listing for my number, but there it is.
Here's the conundrum, if you search the SKF catalog for either of the SKF numbers, they are not listed.
Timken cross reference doesn't have any of those listed.
The SKF numbers I have are 04 12 062H, and AB1-3722(?); also not listed
I am sure they are in someone's database, so I guess I will just call the local bearing suppliers to see if they have an old listing, though generally they do on deal in automotive, which apparently is a different animal.
thanks
thanks
Here you go.
Thanks, I'll check.
I just bought 2ea. BB1-3722     04 10 063H
Though these have seals on them, which I want.
