Sign in to follow this
7502
Potential oil Filter Failure?
3 posts / 344 viewsLast Reply
Did an oil/filter change yesterday and noticed an inner seal/gasket had worked itself loose. Never seen that before. Thought I would post a picture and see if I can learn what it might mean, if anything. The loose piece is the folded up gasket which appears to have originally been stretched around the inner collar. I hope it didn't interfere with the proper functioning of the backflow preventer.  I had been running Valvoline VR1 2050w oil but did add a few oz of Marvel Mystery Oil about 300 miles before the oil change for S & G's. Last engine oil change about 5500 miles ago.
Edited by 7502
more info
I think it’s a sign that Mahle filters aren’t as well made as they used to be (though compare with the inside of a Fram filter).
Diffilcult to say whether that seal being displaced has allowed a path for unfiltered oil to go around. Maybe google image search to see if you can find a sectioned drawing of that filter to try and work out what it does. You can’t wind back the clock now, so slap a new in on, fill up and drive it.
Hmm, haven't seen that before.  But I'm also still using up old stock filters I've had for years...
There usually isn't much pressure across the filter media- there's a LOT of it relative to the
amount of flow, and the paper itself would give before there was enough pressure
to displace a properly- assembled rubber gasket in that location- it just doesn't see much
total pressure.
So I too vote poopy assembly- if you're feeling up to it, cut open a new one, and see how
it's fitting.  I suppose it could have shrunk, too, from improper chemistry...
