irdave
Somebody buy these; BBS 15x7 et20
4 posts / 441 viewsLast Reply
4 hours ago, 2double02 said:
Will a 20 offset with 15x7s work on a slightly lowered 2002 without rolling fenders?
With my Rota 15x6 (forget the offset off the top of my head), on Eibach Pro-Kit springs, no problems at all.  Apparently I'm a lot lower with the MCS coil overs- even with a couple of degrees of negative camber dialed it I'm cutting up the outside of the tread blocks...  But a little fender rolling isn't a bad thing- not for those wheels...
