Just had the front suspension refreshed.  Eibach springs all around. Koni struts & shocks. The rest of the bits BMW Parts, the dust caps don’t fit the new factory strut bearing.
Bought new dust caps from Blundt, same as my old ones, neither fit, just a bit to small diameter.
Where can I source dust caps that will fit the new BMW strut bearings?
JH
Mine were also tight. Lube them up a bit a have another try.
Cheers,
  • Haha 1
Ray
Posted (edited)
Aren’t all strut top bearings supplied now e21 style which are dimensionally the same in all ways except... this one?
 Can you get the equivalent dust covers for an e21?
i fitted my old dust caps but it definitely took a bit of work to stuff everything in.
Edited by Simeon
rtheriaque wrote:
Discovered the same problem several years ago when I fitted new strut bearings.  Took some head scratching--and splitting a couple of irreplaceable black caps, but I came up with a solution involving a short piece of plastic plumbing pipe.  I did a column on the trick; PM me if you'd like a copy.
On 12/4/2018 at 8:56 AM, bianchini said:
I used a tennis ball cut in half.... no joke, fits perfectly. (dont ask about everything else going on in the photo)
Would look right at home on a Golf car.
  • Haha 1
Steve J
& too many bikes
That wouldn't work on my tii with hood insulation. The stock dust caps and brake fluid reservoir cap leaves dents in the insulation.
  • 2 years later...
Hi All!  I had the same problem and 3D printed a set and they work great!  I got so many requests for more that I decided to 3D print more sets.  If you need a set, they are $35 + shipping.
Designed to match the look and feel of the OEM, but a little taller.  They make a great seal and are designed to handle the harsh environment under the hood.
  • Like 4
