Posted (edited)
I have just finished installing a shift linkage refurbish kit, along with new nuts for the flex plate bolts. I pull out of my garage and immediately it starts making this noise (see the video), I assume something on the driveshaft is hitting something. Is this one of those tell-tale signs of something?  I have ground away some material on the shift plate support arm to hopefully give the flex plate bolts some clearance. Has anyone else run into this problem? Edited by FLEMINGO
Can’t quite tell but I assume you are talking about the ‘ringing’ metallic scraping? So this is associated with engine revolutions or road speed? Judging by the foam sealing ring being pressed hard against the transmission tunnel (in your video) it’s unlikely that the shift linkage has settled down and is rubbing on the drive shaft (most likely culprit). I think you just need to get underneath and eyeball and listen for whatever is rubbing as you slowly rotate the driveline over your head.
also, checking your terminology: when you say ‘flex plate’ are you referring to rubber donut in the driveline? This is generally called a ‘guibo’. I was initially confusing it with a flex plate from an automatic transmission flywheel (unless that’s what you meant).
https://en.m.wikipedia.org/wiki/Flexplate
rtheriaque wrote:
Only way to know is to put it back up in the air and take a look at everything. It sounds like something rotational is only lightly touching. Get under it, rear wheels off the ground, in neutral, and slowly turn the driveshaft... A bright flashlight will help identify any shiny worn spot.
Good luck. It’s probably something simple
Ed
'69 Granada... long, long ago
'71 Manila..such a great car
'67 Granada 2000CS...way cool
FLEMANGO...hard to tell from video but you can get a rattle on the shifter between the ball with small shaft at base plate and the black on your car shifter handle...good luck with this.
make nothing happen…
Guibo nut/bolts loose and hitting the shift mechanism?  Not that I've ever had one of those come loose or anything...  Especially if you can feel it in your hand on the shift lever.
Dave.
If you have the late model shift linkage the "dog bone" piece of the linkage only goes in one way or it will rub the drive shaft.
George S Patton
  • 1 month later...
Mine is doing the same thing, did you figure out what it is? I checked, and it is not my shift linkage hitting the drivetrain.
1976 2002
+1 for irdave's "Guibo nut/bolts loose and hitting the shift mechanism."
I had the same ticking noise post-intall of a new guibo.  One of the 8 bolts or nuts was hitting something (do not remember exactly what).  Not much room around a spinning guibo.  I had to loosen all 8 of the bolts and retighten them carefully, individually, and accurately...then repeat a couple of times.  Took a really long time to do so b/c I learned the guibo and drive shaft had to be aligned carefully, accurately, just-so, and in the right alignment with NO, repeat, NO stress in the guibo.  I had my friend, Ben, help, show, and advise me.  Also got telepohnic help from this site (re: install of guibo) and from a real Fountain of Knowledge, Mike Pugh.
However, your ticking might be something else...
Larry
Double check the tightness of the shift tower support brace. If loose, the shifter mechanism will rub against the driveshaft.
Found the cause of the noise, one of the 17mm nuts that holds the drive shaft to the tranny fell off, and the bolt back out and was hitting the tranny!
Recommend I use loctite when replacing?
1976 2002
Yes loc-tite and change all the nuts to the self locking type the one in the picture looks like it's just a regular nut.
George S Patton
Posted (edited)
OEM hardware specially in this case guaranteed to work and should not experience like you did if installed correctly. IMO there is no need for LOCTITE THREADLOCKER BLUE 242
08    Hex bolt    26111102144    M10X61    (8)
11    SELF-LOCKING HEX NUT    07129964672 M10 (8)
https://www.bmwmobiletradition-online.com/bmw/showparts.do?model=2215&mospid=47140&btnr=26_0136&hg=26&fg=10
Edited by Buckeye
76 2002 Sienabraun
2015 BMW F10
Thank you!
1976 2002
Okay, one problem fixed, and now another one shows up. I’ve got transmission fluid leaking significantly. I attached pictures, and it is all over the place!
Any common culprits? I just replaced the speedometer o-ring, and it looks like the leak is coming from somewhere higher.
1976 2002
