Price: $950
Description:
I bought the engine about a year ago for an 02 project but have decided to go a different direction. Everything as stated is new and is in good condition. I prefer to sell it locally if at all possible but might could ship if absolutely necessary.
Specifics:
1972 m10 tii block bored +2 New Mahle 9.5:1 Piano top pistons
New Chrome Molly rings
New standard size crank and rod bearings
New double row timing chain and guides
New water pump
Original oil pump and pickup
Oil filter housing Oil pan
New front and rear seals
Asking $950
Did you do the rebuild or buy it that way?  I’ll be in Charlotte tomorrow.
Thanks,
Brad
1960 Austin Healey Sprite | 1974 Ford Bronco | 1974 Porsche 911 | 1989 Mustang GT | 1995 Porsche 911 | 2017 Porsche 911 | Always in Search of a BMW 2002
I bought the complete engine from a resto shop in Atlanta. The first thing I did when i got it though was have a local engine builder go through and check everything out. He dismantled the engine and mic'd the crank and it was good and the bearings are new. He also checked the bores and ring end gaps and again, everything measured out nicely.
Let me know if you have any other questions.
Jerry
I'm having trouble believing it to be a Tii engine.  Timing chain cover is an std carb engine cover.  I don't see any oil return opening for a KF pump oil return.  With 2 new pistons, do they weigh the same as the other 2?  The crank pulley looks like one for a E21 chasis.   These questions need before it is worthy of a Tii engine listing.
I think he also means block bored plus 2 versus only 2 new pistons.
Posted (edited)
The KF pump oil line a̶c̶t̶u̶a̶l̶l̶y̶ ̶r̶e̶t̶u̶r̶n̶s̶ ̶t̶o̶ ̶t̶h̶e̶ ̶t̶i̶i̶ ̶o̶i̶l̶ ̶f̶i̶l̶t̶e̶r̶ ̶h̶o̶u̶s̶i̶n̶g̶.̶ ̶
That's a standard '02 water pump also.
I believe it's a tii block -- that someone wished to use in a standard 2002.
Cheers,
Edited by ray_
oopsie
Ray
3 hours ago, jerry-02less said:
The piston domes are 6.8mm high
That should mean 9.5:1 compression in a stock head.  I believe that is standard Euro tii configuration.
BMWCCA  Member #14493
www.2002sonly.com
Ray, what are talking about, the oil line from the filter housing is the feed line, the drain back is a hose that fits onto a nipple not unlike the dipstick tube nipple. You can see on the block where someone has removed the nipple, tapped the hole and installed a threaded plug.   Someone was probably going to use this with carb or carbs.  With the head stuff that this fellow is selling, a couple of good 40 dcoe;s, a worked over head and a good exhaust, this could be one sweet little engine
Thanks, Rick
Thanks, Rick
Oops.
That's right.
Cheers,
Ray
