Is it possible to buy new, identical safety wire bolts that go at the bottom of the front struts?
If not, I think I should be able to use regular bolts with drilled heads...? What have you guys done here?
'74 Verona
Don't use regular 8.8 bolts the factory ones are at least 10.9 or maybe 12.9s failure of these bolts equals crash bang boom.....every time.
George S Patton
Posted (edited)
price has absolutely NOTHING to do with it’s performance, it’s just another example of BMW’s pricing algorithm not functioning like it should in regards to classic cars parts... until they care enough to put someone on the job, we’ll continue to see pricing anomolies like this.  FYI they were around 7.50 each about a year ago.
drilling 10.9 bolts (from a reputable source like bellmetric) is your best bet.
Edited by AceAndrew
Posted (edited)
Neat, do you have a part number or a link for the first bolts you pictured (assuming they are not OEM hardware)?  Pictures are nice, but more information is needed if we want to consider it an alternative to drilling the bolt head.
Edited by AceAndrew
consider restoring the safety bolts you have ? I did, shake in can of parts cleaner, hot soap and water,
shake in can of OSPHO let dry, hand wipe and wire brush, coat with Boe-Sheild
unless they are badly corroded or damaged
Posted (edited)
That’s OEM part. I’m not aware of aftermarket of such part. That bolt should not be substituted. BMW pricing is out of control, But sometimes on some parts you don’t have a choice.
Edited by Buckeye
76 2002 Sienabraun
2015 BMW F10
Good point Buckeye, that would weaken the head, which very importantly needs to hold this struts on. I guess I should just splurge on some new ones...
I don't want to try to restore the old ones. They are particularly nasty.
'74 Verona
Jaymic has them, I bet Blunt does too.
i would piss around with these they are too important, you don’t want a suspension component going walksbout mid corner!!
Posted (edited)
I've got mine safety wired using my refurbished originals when I did the front-end.
Anything wrong with just using high-grade standard hardware and say, loc-tite Green?
Its high-temp and anti-vibration, good enough for keeping your flywheel attached to your crank. Might take a torch to get 'em back out thou.
If it were OK, I'd still use some marking paint and check periodically for rotation.
Edited by 2002Scoob
