kpatler
Sold FOR SALE: Chamonix 1971 BMW 2002
11 posts in this topic Last Reply
(edited)
Price: $19995
Description:
Year: 1971
Model: 2002 Coupe w/factory sunroof
VIN: 2573303.
Mileage: 153,890 documented miles.
ASKING PRICE: $25,000 OBO
Date of Manufacture: April 30, 1971
Sold new in San Leandro, CA and lived its entire life in the Bay Area. I have the certificate of manufacture from BMW, and even the original bill of sale! And many, many, many records since new.
Work performed / upgrades made during my ownership:
Drivetrain Maintenance & Upgrades:
  • Bilstein Sport Struts
  • Ireland Engineering Springs
  • Ireland Engineering End Links
  • Ireland Engineering Sway bars front & rear
  • New 3 dot spring pads
  • New upper strut mounts and bearings
  • New trans mount
  • New engine mounts
  • Rear trailing arm bushings
  • New center link
  • New tie rod ends
  • New guibo
  • New diff bushings
  • New diff seals
  • Brake fluid flush
  • New Rear trans seal
  • New center support bearing / bushing
  • Shifter linkage rebuilt
  • Transmission serviced, seals & fluid replaced.
  • Fresh alignment 2 weeks ago
  • New front lower control arm bushings
  • Brakes completely replaced:
  • New Brake calipers
  • New Front brake pads
  • Rear drums refinished
  • Ireland Engineering SS brake lines
  • New OEM Shift Boot
  • New Fluid / Flushed
Interior:
  • Kooglewerks Shift Knob
  • Kooglewerks Center console assy
  • Kooglewerks Ebrake Handle
  • New Nardi Steering Wheel
  • New Nardi Steering Wheel Hub
  • LED Tail Light bulbs
  • New flasher relay
  • New Driver lock cylinder
Engine / Fuel system work:
  • New Ireland Engineering Stainless Steel exhaust
  • New alternator bushings
  • NOS BMW down pipe
  • New Headgasket
  • Replaced cylinder head with correct (rare) 121 Head
  • New valve guides
  • New timing chain
  • New valve cover gasket
  • New Radiator Fan blade
  • New Fuel Filter
  • New fuel filler neck
  • New Fuel lines in engine bay
  • Re-jetted Carb
  • New thermostat
  • Coolant flush
  • Oil change 51.5k miles
  • Oil change 53.6k miles
Ignition System Upgrades:
  • New distributor cap
  • New rotor
  • Pertronix electronic ignition
  • NGK BPR6EIX Plugs
  • Ireland Engineering 8mm performance plug wires
  • New Bosch coil
Exterior Updates / Upgrades:
  • New tail light lenses
  • New tail light gaskets
  • Period correct 4x100 15x7 et24 Panasports (Original 13” Steelies with great condition hubcaps included)
  • New 205/50/15 Bridgestone RE-71R with ~2000 miles
  • NOS Flag mirror — not currently installed but included
  • New Wipers
  • All stock parts are included (suspension, wheels/tires, steering wheel, etc.)
Known Issues:
Rust spot at base of rear window. Have been monitoring it closely and intended to repair during a full respray, but decided to keep it a driver’s car and not go full concourse.
Door seals need to be replaced
Pass side door latch rework needed (only opens from inside)
Dash cluster backlight inop
Dash has two fine line cracks
Here are some pics. I’ll add some more detailed interior shots, and engine bay pics as soon as I can.
5b516eda4e193c56aa06b4bc5c7fd251.jpg&key=05c929bb09bfd492246fc9357105be054d7db44bbde07125da7d9035facec0f0
8d303f88283519e733559ad663e98e4f.jpg&key=0ef052f0d763f95dc22f3fb9072e6f3b0a1188d23dcd166a933700dc57f79ccd
40a3a9ef7c79211405f9b3640c078ece.jpg&key=e6d3ee563cb92357508d3c7f76a4bb8dc3159cbf475d761e2890993aefc5f26b
3dddd2724da9f4df159049d93bd7e4d5.jpg&key=cb050b3a71fd6c4fd9c2b5391305573522069bdfe1d5df35db0f2044442b8193
aeb537984f798f06d307de257dbacdee.jpg&key=3746c038981ce003b257a6b00d7074c2caa5422dea641436170413db03b2e84a
8821ddc3ffd37627e321a43b85288e74.jpg&key=6875a749d4d1cc525cf5db604aacb6cf61d5710f8aa2300c499a0dffaa24ea2a
0eccd74635412f0e5064a8953f001c43.jpg&key=d1390d3d946608b8ddc15d6ef687a14b25dcfc1755455ea1bc8dd62c1178c906
69c89ace547262d62e2c02e8c216fadf.jpg&key=f2dbc7e45e411b6cadc82dbf216954440e690b382ef139e934896f913553dbec
08fd34f79555d55840346d1f8d2dba19.jpg&key=cf029244d0d2b51a49ec128c1dfa6f51f14e36a53a4322209fb0f2187c5039bf
38a84060715cd4b5a04b95adfe500f74.jpg&key=c78891f3455b688b9d7b09f6f5e9f250ed4617e81f65bde47e796874c6bea65a
Edited by kpatler
