For those Tii owners with electric radiator fans......
water neck for the coolant line that runs to the warm up regulator. I had a machine shop add a new hole and enlarge the smallest of the existing holes to hold a 320i style temp switch. -J
hole in the lower tank, you can get a threaded brass "bung" out of a junk copper/brass 320 radiator and have a radiator shop solder it in (or do it yourself if you have a propane torch). The bung has a lip on the outer edge, so as long as the bung is a snug press fit in the hole, you'll get a good solder joint between the lip and tank.
