Tangentially, it's '02 related because this part is going into my '02.
The photo is of the fuel pump and level sender from a late E30. I want to know if the electrical connector for the sender, the black connector on the left (not the pump connector, I've found that), is available new so I can make a better wiring harness for it. I've dug around *a lot*, but haven't come up with any threads about this, despite all the EFI conversions. RealOEM isn't being helpful today, so I thought I'd ask.
I'm too lazy to take the seat out and get to the tank to verify, but if it is a standard AMP 3-pin (female) connector, it would be this:
http://www.realoem.com/bmw/enUS/showparts?id=1003-USA-11-1989-E30-BMW-M3&diagId=13_0282
#25, 26. You will have to get your parts supplier to match up the actual pins; you can get them with our without wires attached.
Or does the fitment plug inside what you are showing?
Always scrounge or buy components with pigtail connectors. You need one of these, 3 wire. signal, ground, low level wires.
Hijack: Need an E30 Electrical Distribution block for battery relocation.
No cable required.
Apology for hijack
1974 2002 Tii-SOLD
1978 911SC Coupe
1988 Landcruiser
2020 M2 CS
  • 3 years later...
  • 10 months later...
