Wipers won't stop!
URL: http://www.lovingeveryminuteofit.com/bmw2002/
Luckly I don't have the actual blades and arm pieces on yet, but the motor won't stop turning the internal wiper arms. If I turn the wipers on they go at the same speed and I can set it to high and it goes at high speed. I then turn them off, and they shut off for about 3 seconds and then start up again. Anyone else experience this ever?
Lars
I just had this happen to me as I accelerated on to an on-ramp a couple days ago. Washers came on as well. The washer pump fell off the bottle and onto the header. The ground wire burned through and shorted the circuit.
I diin't know we had "intermittant wipers"! You could always move to a rain forrest.
i traced mine to a short from the alarm system
(which i removed afterwards). check that the turn
signal/wiper arm is well connected and grounded.
also could be the relay. i have spares of both so
let me know if you need one. 1 week to hermann
huh?
It's the relay (or wahtever they call it). I just had the same problem on my wifes''02 and used the Haynes manual to check out the problem. Found that the "delay relay " was the culprit.
