Horn relay is NLA ??? Pacific BMW says so ...
Went to the counter when to pick a few things up and found out that the horn relay is NLA. How can that be ?
he has some of the older NLA relays and I think the horn relay is one of the round type used on earlier '02's. My 1969 2000 (4 door NK bimmer ) uses this type.
Tim
'74 2002
'69 2000
Unless you're after a complete stock restore, there has to be alternatives out there.
For example, my Hella horns came with a relay which fit nicely in the stock location on my '76.
Somebody should figure out some applicable part numbers and post. I can look at my Hella one if needed as well.
BigDog
'76 2002
Doesn't look like the original tin can relay though. It's a black plastic
cube with a single tab to mount it to the fender.
Matt@
Max
